PCM to DXF help
PCM to DXF help
Is there anyone can convert this PCM into a DXF or SVG. Thanks for any help
viewtopic.php?f=6&t=30406&p=184078&hili ... or#p184078
Re: PCM to DXF help
waylon wrote: ↑Sun Jul 10, 2022 8:37 pm Is there anyone can convert this PCM into a DXF or SVG. Thanks for any help
Re: PCM to DXF help
Very nice thank you so much !!!
Re: PCM to DXF help
I have several pcm files that i have collected over the years. Can someone convert them to dxf? Hopefully someone one can use them as well. Thanks.
Re: PCM to DXF help
Two more.
Re: PCM to DXF help
I spent some time cleaning some of these up. Some were cut paths needing converting to drawings, and others has many overlaps, etc. needing editing.
They should all be fine now with no intersections detected.
Re: PCM to DXF help
Re: PCM to DXF help
Re: PCM to DXF help
Thank you very much. Like I said, I've had these files for some time and didn't have a way to open or modify them.adbuch wrote: ↑Sat Jan 07, 2023 9:08 pm I spent some time cleaning some of these up. Some were cut paths needing converting to drawings, and others has many overlaps, etc. needing editing.
unicorn.dxfTrout 2 x4.dxfskullgasmask2.dxfpatriotic deer.dxfLoveArrow.dxfFFA Baraboo Logo edit 1.dxfAustralian Shepard.dxfCircle.dxfClarksdale Bikes pcm.dxfCOFFEE.dxf
Re: PCM to DXF help
Re: PCM to DXF help
Re: PCM to DXF help
Re: PCM to DXF help
Your are quite welcome! No problem at all, and happy to help.maghunter120 wrote: ↑Sat Jan 07, 2023 9:45 pmThank you very much. Like I said, I've had these files for some time and didn't have a way to open or modify them.adbuch wrote: ↑Sat Jan 07, 2023 9:08 pm I spent some time cleaning some of these up. Some were cut paths needing converting to drawings, and others has many overlaps, etc. needing editing.
