Can someone draw this for me in SVG. I bought a CNC that uses inscape and I'm having hell getting use to the new software. I used Qcad for several years. I want everything to stay except the eyes, star and nostrils. it will be in a 18x24 inch sign.
I'll pay to have it done. Thanks
Texas Longhorn - Need Help
Re: need help
You should be able to just select the things you don't want and delete them. Then save as svg.
Re: need help
Post the dxf or svg that you have and you may have more luck since someone won't have to redraw the entire design just to eliminate a couple elements.
Re: need help
I have sent you a PM.Jode wrote: ↑Sat Jul 24, 2021 12:38 pm Can someone draw this for me in SVG. I bought a CNC that uses inscape and I'm having hell getting use to the new software. I used Qcad for several years. I want everything to stay except the eyes, star and nostrils. it will be in a 18x24 inch sign.
Re: need help
Here's the SVG file.
- ROKCRLER
Re: need help
Heres my attempt..
Two versions
See if they'll work for you
Edit:
This might be better as a double layered sign
Two versions
Edit:
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: need help
Hi Jode,
Here is the original in svg format.
Here is my version for cutting as a single piece.
If you decide to use a layered approach using two separate pieces, then here are the steer and Texas outline as individual files.
Re: need help
I missed the part where you said you wanted everything to stay except the eyes, star, and nostrils.
Here are the same files with these parts deleted.
