Hi Guys
Wondering if anyone can help converting this harp into a DXF.
Thanks in Advance
Celtic Harp
Re: Celtic Harp
Here is an Inkscape trace of your photo exported as dxf. I used IrfanView to resample/resize your original image (to create more pixels/higher resolution) and Paint.net to increase the brightness/contrast in order to achieve a complete scan. Then Inkscape to trace and export dxf.
I notice that you have asked for help with creating dxf files from your images previously in some of your other posts. If you are interested in learning how I created your dxf files on your own using free programs, feel free to send me a PM and I will lead you step-by-step thru the process.
I assume you are planning to do a layered piece, otherwise some of the pieces will fall out when cut.
Re: Celtic Harp
Thankyou so much @adbuch it is greatly appreciated
Re: Celtic Harp
You're welcome! Let me know when you are ready to start learning how to do your own dxf tracing.
Re: Celtic Harp
What size is this harp
It looks great
It looks great
Re: Celtic Harp
It can be any size you want. Just scale to the size you need.
Re: Celtic Harp
AS David is pointing out some drawings can take a few program to message the image to get the result you need for a DXF that can be cut. As he suggests with some complex drawing things work out better by breaking up the image and making it a layered finished project. After you see it done it becomes easier to understand and then completing the work on your own is easier. This sometime makes a big difference and it turns out better.
Two examples
Two examples
Re: Celtic Harp
Thanks again
Re: Celtic Harp
Those are great examples Tom! And the different colors really makes it pop.
