Motor issue or...?
Arclight Hardware discussion forum.
Deezl Smoke
Motor issue or...?
Post by Deezl Smoke » Mon Dec 20, 2021 3:28 pm
2019 Arclight 6x12, Hypertherm 105, sheetcam, Commandcnc.
Lately this issue has been popping up on the first cut. It happens only on the left as you face the end of the table from the home position.
So at my expense, I then have to re-cut and the second cut always turns out fine. Do I need a new motor on the X axis, or what are some possible causes of this?
Second cut.
Thank you for any help.
Re: Motor issue or...?
Post by weldguy » Mon Dec 20, 2021 4:26 pm
No, you do not need a motor. I suspect your gantry is driving into or over something. I would run that program with the plasma cutter turned OFF and closely watch as this happens to see if you can determine whats going on. Look closely at your rails and bearings while this is running and just keep running it over and over again until you see it. If you don't think its a mechanical issue after doing that please post your code.
TJS
Post by TJS » Mon Dec 20, 2021 4:48 pm
How thick is that material. There is a large discussion over at the CandCNC forum. We as others have issue with torch diving and there are settings in the Config that are recommended. Not saying your torch is diving but mine does on 3/8" or thicker with my THC on. Cut direction looks to be counter clockwise (however I may be wrong from your lead in pic). I always thought the cut direction on outside cuts is supposed to be clockwise or something like that. However I am with Weldguy, something has some slop.
Deezl Smoke
Post by Deezl Smoke » Mon Dec 20, 2021 10:37 pm
Great idea. I try to keep things as clean as I can given the place I have to operate the table. But there very well may be something like some pierce splatter etc. where it should'nt be. Thanks so much for the idea.
Deezl Smoke
Post by Deezl Smoke » Mon Dec 20, 2021 10:42 pm
This material is .875" thick A36 mild. Yes, the cut direction is counterclockwise. The inside cuts are clockwise. I assume that is correct for my torch being a Hypertherm.
I had torch dive issues some time ago. I found deleting a reloading the toolset helped. Then I added several path rules like turning off dthc a few thousands before a corner sharper than 45 degrees, and turning it back on a few thou after the corner etc. Things like that really made the cuts nicer.
Post by weldguy » Wed Dec 22, 2021 9:43 am
Sounds like you have your cut direction backwards, check out this topic viewtopic.php?f=202&t=30272
Not that cut direction will have anything to do with the problem you originally posted about but it is important, particularly when cutting thicker materials to try and maintain a square cut with minimal bevel.
Curious to hear back about your original issue and if you found something loose or crap on a rail or something like that.
Deezl Smoke
Post by Deezl Smoke » Wed Dec 22, 2021 2:43 pm
Yes, I see that now after TJS mentioned it, I looked it up on here with a Jim Colt thread. Now I have to work on that too. I have no clue how that got changed in the sheetcam.
Going to diagnose the table issue over Christmas. I have a feeling it may have some pierce splatter stuck in the gantry gear rack or something from before I bought the refrigerated air dryer. I had a bad series of slow piercing with a lot of splatter blowing upward into the Z mechanism. May have some stuck in the X rack. I will report back when I find it.
TJS
Post by TJS » Mon Jan 10, 2022 10:04 am
THere are some good posts on thick material to combat the volcano effect. I have to find it. I think it is something like a longer lead in and longer delay or moving while it is piercing. I cannot remember.
Post by acourtjester » Mon Jan 10, 2022 11:09 am
A simple way to find the location of the bump is to single step the G-code, no plasma. As you images show you may be always starting the table first cut at the same location and it only happens there.
Post by djreiswig » Mon Jan 10, 2022 9:31 pm
I use a ramp pierce on thick material. Plunge speed same as cut speed. No pierce delay. Makes the slag shoot out behind the torch.
TJS
Post by TJS » Tue Jan 11, 2022 7:10 am
Can you share how you do that.
Post by djreiswig » Tue Jan 11, 2022 10:14 am
Ramp pierce is an option in the sheetcam tool settings. I use a perpendicular lead in the same length as material thickness. Set plunge rate whatever your cut federate is and set pierce delay to 0.
TJS
Post by TJS » Tue Jan 11, 2022 10:27 am
Thanks. I never noticed it in Sheetcam. I will take a look.
Post by djreiswig » Tue Jan 11, 2022 8:55 pm
Post by djreiswig » Tue Jan 11, 2022 8:56 pm
I tried the wiggle, but it seemed to blow slag back up into the nozzle. Maybe it would work if you set it to wiggle more.
Return to “Arclight Dynamics”
Industry Pros use FastCut CNC
