I am looking for recommendations on tooling I can use to square up the edges of holes or slots on thicker material. I know nature of plasma cutting will result in some taper to the edges, especially thicker material like 1/4" and up but I want to be able to clean up the edges and improve it in some cases.
What I am looking for is preferably a die grinder bit with 1/4" shank that is not a double cut carbide burr because they grab and are hard to control. I have tried sanding drums for port and polishing of various quality and grit and design, they all burn up in about 30sec. I'd be interested if there are any diamond or sintered style abrasive bits with 1/4" shanks.
Appreciate any insights or recommendations.
Looking for tool recommendation...clean up cut holes
Re: Looking for tool recommendation...
I have never had much luck doing that. The cut edge is so hardened it dulls out everything, smaller holes I can get away with a cobalt drill bit but larger holes that doesn't work so well. Carbide burr in a die grinder with some WD40 is about the only thing I have found that will work decently. Curious if anyone else has found anything else to work well.
Re: Looking for tool recommendation...clean up cut holes
You can buy single cut burrs.
