It is currently Mon Oct 22, 2018 5:02 pm
Recommended part spacing vs thickness?
Share tips and tricks you know of in this forum. Plasma cutting, material handling, metal finishing, marketing, or anything that you feel is helpful.
AD80
Postby AD80 » Tue Jul 25, 2017 5:37 am
When nesting parts - Is there a rule of thumb with regard to part spacing and the thickness of material or amps used?
Thank you!
AD
tnbndr
Re: Recommended part spacing vs thickness?
Postby tnbndr » Tue Jul 25, 2017 8:05 am
1/4" has always worked for me.
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
motoguy
Postby motoguy » Wed Jul 26, 2017 3:20 am
2.5x kerf is a good rule of thumb, IMO.
RobinHillMachine
Postby RobinHillMachine » Sun Jul 30, 2017 9:14 pm
I have this file that you can burn and find out what your minimum spacing is.
https://robinhillmachine.com/epages/100 ... s/nodetest
Julie's the name, DXF is the game. http://robinhillmachine.com
AD80
Postby AD80 » Tue Aug 01, 2017 5:29 pm
Sorry for the late reply - thanks for the suggestions!
I'm learning 8-10mm part spacing seems to work well on material thickness upto 15mm, and anything thicker than that - 15mm part spacing.
I could probably get things nested closer messing around with lead ins/outs, but I'm not that advanced yet!
Return to “Tech Tips”
