looking for flat-pattern formula
[email protected]
Post by [email protected] » Fri Oct 12, 2018 10:56 am
I'm wondering if there is any formula for drawing boxes that are tapered,(there is a better name I'm sure,) for exmpe I am building a box with the top 12''x12'' and the bottom 8''x8'' with the depth being 3.5'', 3/16 material, I know in solidworks you can build your box and then flatten it to get the pattern, is there any other program that will do this?
lockeyone
Re: looking for flat-pattern formula
Post by lockeyone » Fri Oct 12, 2018 6:07 pm
Take a look here. Might get you close.
https://www.templatemaker.nl/
Epilog Mini 24 60watt, 2013
JohnnyC
Post by JohnnyC » Fri Oct 12, 2018 8:33 pm
nice page
[email protected]
Post by [email protected] » Fri Oct 12, 2018 10:48 pm
I've tried that and could'nt make anything work.
lockeyone
Post by lockeyone » Sat Oct 13, 2018 8:58 am
I think it does. I typed in your dimensions into the Trapezoid style. Took PDF into my drawing program and removed the tabs. All shapes needed are there. If you have a break then you could cut less pieces for less welding. May have to adjust dimensions if you are trying to get outside or inside dimension right on.
At least I think this is what you are needing.
Old Iron
Post by Old Iron » Sat Oct 13, 2018 11:44 am
Worked like a charm. Thanks Lockeyone for the link!!!!!!!!!!!!!!!!!!!!!
[email protected]
Post by [email protected] » Sat Oct 13, 2018 2:23 pm
I see, must not have used the right template formula, thanks a lot!
