It is currently Fri Oct 19, 2018 11:51 am
Harbor freight air dryer
gaolista
Postby gaolista » Sat Oct 07, 2017 7:53 pm
We installed an air dryer from harbor freight and don't seem to have any better results. Our last trap before the plasma cutter is still turning deccident balls pink. Their isn't anything in the trap on the back of the plasma cutter but our cuts aren't piercing throughout the entire operation. Also the rate at which the balls are turning pink are the same as before we installed the air dryer. Anyway, if there are any of you out there that use the harbor freight dryer and can look at the photo to confirm my gauge is reading correctly that would be great. Thanks for the help.
little blue choo
Re: Harbor freight air dryer
Postby little blue choo » Sat Oct 07, 2017 10:18 pm
Mine works like a charm and runs at about 30 PSI low side pressure. Same as in your picture.
Rick
Rick
Arclight 9600 4x8 table
gaolista
Postby gaolista » Sun Oct 08, 2017 2:29 pm
little blue choo wrote:Mine works like a charm and runs at about 30 PSI low side pressure. Same as in your picture.
Rick
Ok, thanks for the reply.
I'll have to figure out why I still have so much moisture between the it dryer and my plasma cutter.
Just using 3/8 hose, do you think I need to be using pipe?
Thanks again for the help
Dana gear
Postby Dana gear » Tue Nov 28, 2017 5:37 pm
Depends where you are at in the world, Death Valley no humidity ,Hawaii lots of humidity.
Our shop is in Northern California, in the winter high humidity, we run automatic tank drains on all our compressors, you would be surprised how much water these guys blow off in a day. From there a couple of standard water traps and then in the CNC shops where we use Hankison coalescing moisture/oil removel filters fallowed by Hankison air driers and Motorgard air filters, may be over kill but our air is drier then a pop corn fart.
Postby tnbndr » Wed Nov 29, 2017 4:38 pm
Your problem may not be dry air but loss of air pressure during operation.
PM45
Miller 211
RW 390E Slip Roll
ggeh
Postby ggeh » Wed Aug 15, 2018 8:07 am
Rick
I have hf air drier to and the water trap inside the the unit never worked from the very beginning. I took out the float valve and and ran a drain hose from the bottom of the trap to an electric solenoid drain valve that has an adjustable timer and cycle length on it. no more water in my lines. I all so used 1/2 inch pipe on mine and it flows fine.
Return to “Tech Tips”
