inches cut calculator
racn3636
Post by racn3636 » Wed Jun 20, 2018 1:09 pm
Ok I have been searching everywhere for a way to actually figure out how many inches of cutting there are on my designs to properly put a price on it. I know some of the more expensive nesting software does this for you ex: pro nest, but are there any cheaper alternatives out there?
Alex-Speed24
Re: inches cut calculator
Post by Alex-Speed24 » Wed Jun 20, 2018 5:11 pm
i would also like to find this out :)
Post by djreiswig » Wed Jun 20, 2018 10:04 pm
Not sure what you call cheaper, but SheetCam has a report that shows inches of cut and pierce count.
bhamer62
Post by bhamer62 » Thu Jun 21, 2018 2:12 pm
That's a tough one for sure!! I use Sigma Nesting, I get exact inches of cut, number of pierces and all kinds of good info. The only "cheap" way I can think of would take a lil work but be very accurate. If you are using a CAD based program, poly line everything. Click on each poly line and hit your Properties button. It will give you the exact cut inches associated with that poly line. Jot it down on a spread sheet and keep on doin it till you got em all, then add em up. Like I said, it would be extremely accurate but depending on the complexity of the dwg could be time consuming, but sure would beat just guessing......
motoguy
Post by motoguy » Thu Jun 21, 2018 5:39 pm
Sheetcam does reports with # of pierces and inches of cut. Also does cut times, but those are generally way off. What drawing program do you use? There's an add-on, called eCut which I use with CorelDraw. It's quite handy, and can calculate lengths of curves, etc.
racn3636
Post by racn3636 » Thu Jun 21, 2018 9:31 pm
Thanks for the reply. I checked out Sheet Cam and they actually have a free version that works perfect to just bring in a dxf and apply a tool path then go to the report and get the inches cut info.
Thank You Sir
racn3636
Post by racn3636 » Fri Jun 22, 2018 6:04 am
motoguy wrote:Sheetcam does reports with # of pierces and inches of cut. Also does cut times, but those are generally way off. What drawing program do you use? There's an add-on, called eCut which I use with CorelDraw. It's quite handy, and can calculate lengths of curves, etc.
I use Torchmate Cad. Do the inches of cut generally seem accurate on Sheet Cam?
motoguy
Post by motoguy » Fri Jun 22, 2018 10:09 am
Yes. Inches of cut and #of pierces are dead on.
Cut time estimates are apparently accurate for the router folks, but all the acceleration variances for plasma render it near worthless for us.
Fabcor
Post by Fabcor » Tue Apr 07, 2020 9:35 pm
Thank You Sir
I use flash cut version 7, can I download sheet cam free download to find my exact inches cut
Rodw
Post by Rodw » Wed Apr 08, 2020 5:21 am
LinuxCNC's plasmac configuration counts pierces, distance travelled, cut time and a few other things on a separate tab.
Plasmabot
Post by Plasmabot » Wed Jul 22, 2020 1:07 am
What do you charge then per inch and per pierce?
Industry Pros use FastCut CNC
