It is currently Mon Oct 22, 2018 4:00 am
Plasma table clamps?
This forum is for plasma cutting related tools and accessories. Discuss products and tools that have worked or not worked for you.
AD80
Postby AD80 » Tue Aug 01, 2017 5:46 pm
What does everybody use as hold down clamps on their cnc plasma tables?
I could do with either some sort of low profile hold down clamp or maybe a stop to prevent lightweight or small sheets moving when the torch head collides with a part that hasn't fully dropped through the sheet!
My table has wavey slats spaced 2-3" apart.
Cheers,
AD
motoguy
Re: Plasma table clamps?
Postby motoguy » Tue Aug 01, 2017 6:51 pm
AD80
Postby AD80 » Wed Aug 02, 2017 1:54 pm
motoguy wrote:http://www.plasmaspider.com/viewtopic.php?t=15287
Thanks - shame most the pics don't work! :(
_Ogre
Postby _Ogre » Thu Aug 03, 2017 7:50 pm
i edited my photos that photosuckit deleted
check out the thread again
the clamps work well even if the slats are wavey as they clamp the material and snug up on the bottom of the slat
2015cmax
Postby 2015cmax » Thu Aug 31, 2017 12:08 am
That's a great simple solution. Clearly I was over thinking the problem. Every once in a while we get reminded to just get back to the basics. Thx
motoguy
Postby motoguy » Tue Sep 05, 2017 4:01 pm
I have several I've made, modeled on _Ogre's solution. They work great...as long as you have access to the bottom of your slats. As my table has filled up with debris, I find it's difficult to scrape out an opening on both sides for them to get under the slat.
Draintheswamp
Postby Draintheswamp » Tue Feb 20, 2018 10:18 pm
I use f clamps and a piece of 1/8 strap to hold around the edges
Return to “Plasma Cutting Accessories & Related Tools Forum”
