Where to attach plate wire on ohmic
I'm getting ready to put ohmic (CandCNC Feathertouch) on my Bulltear table. It says to mount the module close to the torch. Can I attach the plate wire to the gantry, or do I need to run a wire down to the slats?
Re: Where to attach plate wire on ohmic
I connected mine to the back side of the z-axis and it works great. I was originally going to connect it to the floating head plate, but I had 4 ohms between the floating head and the slats. I checked the z-axis body and found it was 0.1 ohms from the body to the slats.
It all depends on your construction. Just make sure you have good continuity between where you connect it and the slats.
Homebrewed plasma table in the works, NSK linear rails, 3.2:1 belt reduction, CandCNC Plazpak 1A with DTHCIV Ethercut, Hypertherm 85, CommandCNC and SheetCAM
Click here for build post
Got it. Check with an ohm meter. Thanks.
