It is currently Mon Oct 22, 2018 8:22 am
Best slag removal tool I've used so far
DXF
Postby DXF » Fri Mar 16, 2018 4:04 pm
I am installing vinyl laminate flooring in my house and purchased one of these to cut clearance in the bottom of door jambs. I thought I'd try it on slag removal.....works excellent! My plasma cutter doesn't leave very much slag. I am using a Hobart 375 Airforce plasma cutter that's been hit by lightning twice (blew out the circuit board) and it's over 18 years old. I have a Plasma Cam machine that's just as old and 3.11 software with no THC.....still runs great and never had a problem with it. The Rockwell cutter is kind of of heavy but if you turn it on and balance it in one hand not too bad. I've used air chippers, needle scalers and hand scrapers.....have a big pile of different ones that I've bought. Don't want muratic acid in my shop. https://www.lowes.com/pd/ROCKWELL-Sonic ... 1000039771
Dave Hanks
jason.jason.p
Re: Best slag removal tool I've used so far
Postby jason.jason.p » Fri Mar 16, 2018 4:19 pm
I've had one laying around for years but never thought to use it for slag removal :lol: I'm guessing you use the scraper blade?
DXF
Postby DXF » Fri Mar 16, 2018 4:47 pm
jason.jason.p wrote:I've had one laying around for years but never thought to use it for slag removal :lol: I'm guessing you use the scraper blade?
No actually I'm using the cutting blade.....(2) came with it and you can use other companies blades in it or I might make my own and heat treat the edge with a torch.....haven't checked out other blades yet.
Dave
little blue choo
Postby little blue choo » Fri Mar 16, 2018 9:09 pm
Good idea Dave. I have a Porter Cable unit and have never though of trying it. Bet I will soon. Thanks for the idea.
Rick
Rick
Arclight 9600 4x8 table
jason.jason.p
Postby jason.jason.p » Mon Mar 19, 2018 11:58 am
Dave
Wood or metal cutting blade?
DXF
Postby DXF » Mon Mar 19, 2018 1:56 pm
Dave
I am assuming it's a wood blade but.....same one I used to cut the door jambs. A scraper blade would probably work also.
