Downloading DXF Files for InkScape
I am having trouble opening any files I have downloaded on this file share forum in inkscape. Any help troubleshooting this will be appreciated. Thanks
Re: Downloading DXF Files
use import function in inkscape maybe
Shouldn't be an issue. Are you just not seeing anything once you've opened the file? Have you tried zooming out to see if it just off in the distance somewhere?
There is a trick I use when that happens, download QCAD (free) and open the file there then save it with the R18 DXF format I just add a letter to the original name. Then you can open it in Inkscape, it seems the DXF file format is not universal, each software package may differ slightly.
Re: Downloading DXF Files for InkScape
Where do you find the R18 DXF in QCAD. Can’t figure out how to do that Thanks
here it is
Thanks. That’s the answer to my biggest problem on files
