It is currently Thu Oct 18, 2018 7:48 am
Combining text to a solid rectangle
Searchman
Postby Searchman » Mon Dec 25, 2017 9:47 am
I want to combine text to a solid rectangle bar, so when it is cut on a CNC plasma table the letters and solid bar are one. I have searched the Web on this subject and found videos with similar applications. Most videos are not done very well. Either the audio is distorted with background music or the person doing the video is jumping the curser around so fast it is difficult to follow what the demonstrator is actually doing. A typed instruction step by step would be so helpful.
tirediron
Re: Combining text to a solid rectangle
Postby tirediron » Mon Dec 25, 2017 10:59 am
I'll give it a try. Move the text down to the bar - just so the bottom of the text is into the bar. Next us your mouse and draw around the bar and text. Next go to path and select combine. Then you should be able to move the unit as one.
little blue choo
Postby little blue choo » Mon Dec 25, 2017 12:07 pm
It would be a lot better if you let us know what software you will be using to draw it. That way someone with the same software could give you a step by step.
Rick
Rick
Arclight 9600 4x8 table
Searchman
Postby Searchman » Mon Dec 25, 2017 12:48 pm
I thought I was posting in the Inkscape forum? Inkscape is the Software I am using.
Postby acourtjester » Mon Dec 25, 2017 2:07 pm
Ok with Inkscape you would have the text laid out and then draw a box, move the box up to touch the bottom of the letters.
This is done without either being a path, Clip on one then hold the shift key and click on the other. then move to the path menu and go down to the union and click on it. This will unite them together then click on "fill/stroke and remove the fill and click on the stroke and make the stroke thickness you want.(very small for plasma cutting 0.005") when you do this they will now have a path.
Everlast PM 256 tig
Searchman
Postby Searchman » Mon Dec 25, 2017 8:29 pm
Excellent instructions. Worked very well. Merry Christmas
steel 35
Postby steel 35 » Mon Dec 25, 2017 10:32 pm
Searchman wrote:Excellent instructions. Worked very well. Merry Christmas
Good enough I copied them :lol:
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
Return to “Inkscape”
