Thermal Dynamics Cutmaster 101 Automation Interface Kit
borris
Post by borris »
Hello All:
I have an older Cutmaster 101 (Metal Case) that I use with my very old plasma table. The unit does not have an automation interface. I hard-wired an interface board into the cutmaster including a transformer wrapped around the hot lead for my voltage output. I would like to upgrade to a newer table but still use my Cutmaster 101. EASB/Thermal Dynamics no longer provide the automation interface for this unit. Any idea where I may still be able to obtain an automation interface kit?
weldguy
Re: Thermal Dynamics Cutmaster 101 Automation Interface Kit
Post by weldguy »
I am not sure where you could get one however you really don't need it unless you are forced to use divided voltage rather than raw arc voltage for the height control system on your newer table. Can your new table use raw voltage?
