We currently have a Chinese plasma cutting machine controller, table, and torch with a model number of SH-2012AH-QG, “Unich” LXP1325, hau rong welding LGK7-63 respectively.
I am having trouble making the cnc controller output cuts to the desired 1:1 unit scale.
additional facts that may help understanding the problem;
-When cutting a test line of 94in (2387.6mm) the table controller requires a "scale" value of approximately .338 to produce a true metal cut length of 94in (2387.6mm)
-With the .338 "scale" value selected the travel value in the machine controller is reflects 31.77in (807mm)
-The Cam software is FastCam v7, using the "start" post-control-processor during computer installation
-Upon use the table, controller is reset to factory parameters using "GG3" on the start screen.
-The microstep THC is working well and the plasma machine is striking an arc and cutting through metal with proper height control creating a good finish.
- the “golden ratio” of .338 is producing parts close to tolerance (~.250)
I know support isn’t great for these machines and Im awaiting a return email from the microstep control manufacturer.
Anyone shed some light on my problem?
China cnc controller “scale” ratio issue
Re: China cnc controller “scale” ratio issue
Your machine is setup in metric, I would look at the software to see if there is a selection between inch and metric. Mach has that if so just change the setting.
The cnc controller is in metric at the moment but the g code is also in metric. Fastcam puts out code for the “start” post processor control in metric I assume.
Changing the machine to imperial has made no difference, in fact that make the table axes unmovable and a terrible overdrive noise comes from the motors.
Ok there is a command in the G-code that states inch or metric, you can look at the g-code to see which is set then find out how to change if needed.
sounds like maybe the steps per unit (calibration) are off. Having to fudge the rationj which should be .3937 is saying its traveing further each step than it should . There should be some way to change the calibration If you want o know what it should be then run a "ruler test". There is a calibration calculator at https://www.candcnc.net/knowledgebase/m ... alculator/.
Go to the Fine Tuning (green ) section . It asks you to unput the steps per unit (in inches or mm) and a test move and then ti will tell you what the new steps value should be . Do it all all of the axis
It was the Numerator/denominator parameters in the system setup of the cnc. That’s how’s the stepping motors are tuned. Thanks all
What did you end up with for your settings just curious
