It is currently Sat Oct 20, 2018 7:49 pm
Problem with Cand cnc
Have a question and don't see your manufacturer? Post here and if we get enough action on that manufacturer we will add a forum
OTHill
Postby OTHill » Sat May 10, 2014 12:46 am
Hi I keep having a problem with mach 3 going out of reset.It always happens on a pierce.Any body out there with the blade runner package having the same problem? Can anybody tell me a quick way to restart? Or better yet how to fix the problem?Allan.
beefy
Re: Problem with Cand cnc
Postby beefy » Sat May 10, 2014 12:56 am
Allan,
don't know if this will help you but in Mach, if you go to Config / General Config menu, there's a tick box "Debug This Run". I believe it creates a report of the run, then saves the results to a file in the Mach main folder "LastErrors.txt". I've never tried it myself but I wonder if it would report what is causing the reset.
I wonder if it's a noise issue especially as you say it happens on the pierce.
Keith.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
suttoncnc
Postby suttoncnc » Sat May 10, 2014 5:26 am
Allan,
In the general config menu of Mach there is a debounce timer settings. By default it is set at 0 I think. Run it up to at least 500. You could be coming out of reset when the pierce happens and it generates a spike in the electrical system, changing your debounce timer could fix the issue. Hope that helps
OTHill
Postby OTHill » Sat May 10, 2014 11:54 am
Thanks to both of you!I will try that.Some of these things are wayyyyy over my head.But I think I can follow your instructions your instructions.Allan
Postby acourtjester » Sat May 10, 2014 2:02 pm
One thing you want to look at is if the reset can be reset with out any other things what I mean is there a limit switch you must clear first. If you can just click on reset and it goes away it?s noise. Go to the general setting and change the de-bounce value to about 5000 each and this should help. If the reset cannot be cleared you can look at the diagnostic page to see what is causing the reset light.
Are you using a floating head switch to find the metal surface before each piece if not you may be to close to the metal when you start the piece and then when moving to the cut height you trip the limit for Z. If this is the case the Z limit light should be on.
Everlast PM 256 tig
Return to “Various Manufacturers”
