EZCut help needed
tdmiller12
EZCut help needed
Post by tdmiller12 » Mon Jan 13, 2020 8:12 pm
I recently picked up a EZcut cnc machine from an auction. It looks like EZCut is no longer in business. This machine was build in 2011, and has a Multicam controller. I was told everything worked except the computer. I was able to get the computer working, but get the following error: Could not find a Neti that can connect to MultiCam V-204-P (2416) Port 29. Any idea what this means? Google was not much help, except for telling me what local stores sell Neti pots.
Anyone know if the EZCut software is available to try an new installation?
WyoGreen
Re: EZCut help needed
Post by WyoGreen » Tue Jan 14, 2020 12:52 pm
To me it sounds like some sort of network error, perhaps the computer network card can't talk to the plasma controller?
Router
Laser
tdmiller12
Post by tdmiller12 » Tue Jan 14, 2020 7:38 pm
Thanks. I was able to get past Neti error. It seems like they are communicating (computer and controller). On my Job Console the Virtual Keypad is not showing up. I can't seem to find how to turn it back on. Any hints?
Post by plasmanewbie » Wed Jan 15, 2020 10:57 am
What operating system? Windows 10?
tdmiller12
Post by tdmiller12 » Wed Jan 15, 2020 9:22 pm
Windows 7. This is an older machine, I think it was manufactured in 2011.
Post by plasmanewbie » Thu Jan 16, 2020 3:10 pm
Choose Start-Control Panel -Ease of Access -Ease of Access Center and then Click the Start On-Screen Keyboard button and it should appear :Like
tdmiller12
Post by tdmiller12 » Fri Jan 17, 2020 9:29 pm
Thanks! I will give it a try.
tdmiller12
Post by tdmiller12 » Fri Feb 07, 2020 11:52 am
I have made some progress on this machine. I was able to get a copy of the software for a clean installation. Connection manager says that everything is okay, but on Job Console I keep receiving an error message of "Failed to acquire controller capability bits". Any suggestions on what might be causing this error? Thanks.
gallowayr
Post by gallowayr » Mon Mar 09, 2020 7:00 pm
Tdmiller,
Have you gotten all of your issue fixed?
tdmiller12
Post by tdmiller12 » Fri Mar 13, 2020 11:59 am
No, I still am getting the "Failed to acquire controller capability bits" message. Tried several things, and just can't seem to get past that error.
aplusfences
Post by aplusfences » Sun Jun 28, 2020 1:40 pm
Is there a private company that services EZCUT cnc plasma tables, maybe one of their technicians is available for hire ? I to have a an EZCUT cnc table which currently is working as it should, although I am sure I will need some type of support in the future i.e. parts or software. How expensive is it to convert my machine to a different control software?
Post by tcaudle » Sun Jun 28, 2020 2:42 pm
As with most controllers the software and controller have to work together. As far as I know that controller only works with their software . You may want to investigate a retrofit to a new controller and software . Pick someone that has been around for a while (more than 5 years) and that has support and spare parts for older units. You should be able to replace that system including software for around 3000.00 or less. Multicam has been around for a long time but their market was primarily high end commercial routers
Welcome to the world of Orphan tables.
Industry Pros use FastCut CNC
