China cnc controller “scale” ratio issue
Don't see your manufacturer? Post here and if we get enough action on that manufacturer we will add a forum
JP foodtrucks
Post by JP foodtrucks » Thu Mar 21, 2019 9:58 am
We currently have a Chinese plasma cutting machine controller, table, and torch with a model number of SH-2012AH-QG, “Unich” LXP1325, hau rong welding LGK7-63 respectively.
I am having trouble making the cnc controller output cuts to the desired 1:1 unit scale.
additional facts that may help understanding the problem;
-When cutting a test line of 94in (2387.6mm) the table controller requires a "scale" value of approximately .338 to produce a true metal cut length of 94in (2387.6mm)
-With the .338 "scale" value selected the travel value in the machine controller is reflects 31.77in (807mm)
-The Cam software is FastCam v7, using the "start" post-control-processor during computer installation
-Upon use the table, controller is reset to factory parameters using "GG3" on the start screen.
-The microstep THC is working well and the plasma machine is striking an arc and cutting through metal with proper height control creating a good finish.
- the “golden ratio” of .338 is producing parts close to tolerance (~.250)
I know support isn’t great for these machines and Im awaiting a return email from the microstep control manufacturer.
Anyone shed some light on my problem?
Re: China cnc controller “scale” ratio issue
Post by acourtjester » Thu Mar 21, 2019 10:34 am
Your machine is setup in metric, I would look at the software to see if there is a selection between inch and metric. Mach has that if so just change the setting.
Everlast PM 256 tig
JP foodtrucks
Post by JP foodtrucks » Fri Mar 22, 2019 7:08 am
The cnc controller is in metric at the moment but the g code is also in metric. Fastcam puts out code for the “start” post processor control in metric I assume.
Changing the machine to imperial has made no difference, in fact that make the table axes unmovable and a terrible overdrive noise comes from the motors.
Post by acourtjester » Fri Mar 22, 2019 12:28 pm
Ok there is a command in the G-code that states inch or metric, you can look at the g-code to see which is set then find out how to change if needed.
Everlast PM 256 tig
Post by tcaudle » Fri Mar 22, 2019 12:55 pm
sounds like maybe the steps per unit (calibration) are off. Having to fudge the rationj which should be .3937 is saying its traveing further each step than it should . There should be some way to change the calibration If you want o know what it should be then run a "ruler test". There is a calibration calculator at https://www.candcnc.net/knowledgebase/m ... alculator/.
Go to the Fine Tuning (green ) section . It asks you to unput the steps per unit (in inches or mm) and a test move and then ti will tell you what the new steps value should be . Do it all all of the axis
JP foodtrucks
Post by JP foodtrucks » Thu Mar 28, 2019 6:55 am
It was the Numerator/denominator parameters in the system setup of the cnc. That’s how’s the stepping motors are tuned. Thanks all
Daniel Alstott
Post by Daniel Alstott » Sat Nov 30, 2019 8:35 am
What did you end up with for your settings just curious
