VMD NEST
VMD NEST
Anyone here utilize the nestin feature on the VMD? I have tried several times but when loading a part that works fine when normal job load to cut, itll say things like no layers found? ive tried loading "tooled" parts and just .DXF with no programmed tool path, also have tried loading .DXF from autodesk and that will atleast get me to the next screen. The way I understand it is your suppose to be able to upload tooled and non tooled parts into the nesting part, but that may be incorrect. Even .DXF's from TM cad wont work. I have recently updated the table with the 2020 upgrade. But even with the new software VMD im still having no luck. Also if anyone knows of a video of someone demonstrating the steps? I haven't found much luck and TM tech support doesn't help much when it comes to the nesting part.
