Cable Carrier Project for 2x4 table
bauer
1/2 Star Elite Contributing Member
Post by bauer »
I wanted to build a cable carrier for my Torchmate 2x4 table, so I thought I'd share what I did and what I used. Turned out to be pretty easy and cheap.
Parts:
(2x) cable carriers from Amazon for $28/ea (http://www.amazon.com/gp/product/B00HR6EI2Q)... 25mmx38mmx109cm
(6x) cable carrier support arm $0/ea (https://tinkercad.com/things/jLoAb19CZTk)
The plasma line for my Miller Spectrum 875 is 5/8" diameter and there will also be the auto-height cable in the carrier too.
The cable carrier handled the lines with no issue. The carrier along the gantry is mounted by 2 self-tapped screws into the gantry, and the carrier along the rails runs along the 6 support arms. You can see the carrier is permanently attached to 3 of the arms, and the other 3 are in place to provide support as the gantry rides farther down the extent of the rails.
No issues and went very smoothly.
Brad B, Haymarket, VA
Torchmate 2x4
Thermal Dynamics Cutmaster A40
Miller Spectrum 875 Auto-Line
Miller Spectrum 375
STEEL3470
Re: Cable Carrier Project for 2x4 table
Post by STEEL3470 »
Awesome idea I will be trying it out
poppopsworkshop
Post by poppopsworkshop »
I might have to pick your mind when I get my machine in 2 weeks. I like it.
gusagus
Post by gusagus »
another version of the cable carrier for a 2x2. thanks for the amazon lead for the cable chain
since the carrier is larger then the table I split it in half so cut two and put them side by side, also added the bracket the attach the cable to the Torch hight lifter and the bracket I came up with to mount my Accumove 2 control box under my table.
Return to “Torchmate Forum”
