Stepper motor growling and staying engaged
Bradley
Post by Bradley » Tue Apr 20, 2021 10:46 am
I have a torchmate 5x10 gen x table, with the torchmate red driver box, i purchased it all new in 2016, I believe they switched to the accuemove shortly after this version,
The problem is the stepper motor is staying engaged or trying to drive, i switched motors with a new one and the problem still exisits, its on the one that moves the torch sideways,
Is my problem in the box that generates the signal to the motor?
Bradley
Re: Stepper motor growling and staying engaged
Post by Bradley » Tue Apr 20, 2021 11:17 am
Sorry Table was purchased in june of 2014
Post by weldguy » Tue Apr 20, 2021 12:48 pm
Not very familiar with the Torchmate systems but stepper systems are pretty simple and if you have replaced the motor and have the same issue it must be the driver. If all your drivers are the same you could swap one out from the Y axis to the X and see if that fixes the X before buying a new driver.
Bradley
Post by Bradley » Tue Apr 20, 2021 1:12 pm
okay I will try that
Bradley
Post by Bradley » Tue Apr 20, 2021 6:36 pm
So i swapped the cables from the drivers and the problem moved so is it the driver? I cannot truly isolate as the y axis has male pins for the cable, and the x axis uses females on the board.
Post by adbuch » Tue Apr 20, 2021 10:14 pm
It may be time to replace the driver.
Post by weldguy » Wed Apr 21, 2021 9:58 am
Yes, if that is the case than the driver will be your problem. Hope you are able to get fixed up quickly.
Bradley
Post by Bradley » Wed Apr 21, 2021 12:30 pm
So I physically removed and swapped the mircostepping drives and the problem went away, I was am able to purchase the driver from Flashcut, so I will receive the new driver on friday, that should solve the problem, I was not able to get to act as it was doing before, I also plugged the motor directly to the back of the controller to eliminate a cable problem, its down to whats in the red box of magic!! Swapping the drivers was the right way to go thankyou weldguy!!!
Post by weldguy » Wed Apr 21, 2021 12:46 pm
Your welcome and glad you got it sorted out, Flashcut are great to deal with :Like :Like
Return to “Torchmate”
Industry Pros use FastCut CNC
