Hello! I have a new to me 4x4 DHC2 Plasmacam table with an Everlast 60 cutter. I have a couple of things.
I need a new set of grates for the table if anybody has a set to sell me PM me. I cant not register my machine to order anything from the manufacture as my machine has no visible serial numbers and I have no chance to find the original owner.
I had to repair the touch sensor circuit, the chip for the touch circuit was smoked but since my profession is electronics I decided to repair it instead of replacing it with something else.
I have schematics of the touch circuit and details on how it works so another tech capable person could do a similar repair just PM me if you need help.
After taking apart my control box and reverse engineering it I have to say that WOW! Plasmacam did a great job of packing all of those control circuits in such a small box and on top of it, the X and Y axis are servos with continuous encoder feedback.
have a great day.
4x4 plasmacam table cutting grate and touch sensor
Re: 4x4 plasmacam table cutting grate and touch sensor
You should be able to cut a new set of grates yourself. I think the patterns have been posted here somewhere.
I would cut my own but my table is so bad it's not usable or I would.
I would recommend joining the Plasmacam Facebook group. You don't need to own a Plasmacam table to join and I'm pretty sure you will find someone willing to cut a set of grates for you for a price. Plasmacam charges $249 plus shipping.
grate (set of 16 slats)
Grate is the consumable cutting surface of machine that holds the material being cut. Replace when worn, distorted, or points burned off preventing accurate, reliable cutting. (Grate can be flipped over so the other side is used prior to replacement.)
Part #: D-739
Price: $249
Here is the Plasmacam Facebook link.
https://www.facebook.com/groups/PlasmaCAM.Tips/about
Part #: D-739
Price: $249
Thank you, I have sent in a request.adbuch wrote: ↑Thu Jan 14, 2021 2:48 am I would recommend joining the Plasmacam Facebook group. You don't need to own a Plasmacam table to join and I'm pretty sure you will find someone willing to cut a set of grates for you for a price. Plasmacam charges $249 plus shipping.
Part #: D-739
Price: $249
