Table extension to 4x8 cutting?
crossfab
Post by crossfab » Thu Dec 16, 2010 12:23 pm
Just pulled the trigger on more rails to extend the table. Probably will do away with the factory grate system and add a water table. I am curious if there are any negative effects by doing this. I know how benificial it will be and would like input on those who have modified theirs. I have all the tools to do a clean job, so the work im not afraid of, just the mechanical and software issues. I guess you just choose the 4x8 table on the settings? Also curious about a better torch mounting ideas. I have the dhc, and hypertherm 65. Thanks to all
crossfab
Re: Table extension to 4x8 cutting?
Post by crossfab » Mon Jan 03, 2011 12:00 pm
Thanks.
crossfab
Post by crossfab » Wed Jan 12, 2011 12:46 pm
greywolf
Post by greywolf » Wed Jan 12, 2011 8:30 pm
Going to send you mine to get painted...lol nice job
north shore fab
Post by north shore fab » Thu Feb 10, 2011 11:19 am
looks great! what was your cost in the rails and other material to extend the table?
Tim Yuhas
North Shore Fabrication
crossfab
Post by crossfab » Thu Feb 10, 2011 10:06 pm
Probably cost eight hundred for all. Doesn't take long to do. My next project is to skin it with aluminum and hook up the exaust.
Shovelrider78
Post by Shovelrider78 » Mon May 23, 2011 4:07 pm
Are you using a pivot for the electrical mast to get the full capacity? i would like more indepth details if i could get them. i am wanting to turn my 4x4 into a 4x10. did you just purchase the upper rails for the gantry drive from plasma cam? Any information would be helpful
Thanks.
Darrell
ArtworX In Metal
Bound By Immagination
crossfab
Post by crossfab » Wed Jun 01, 2011 8:47 am
Yes. New rails and one gear track cut down will allow a 9' 5" table. Don't cut the rails just but the up. The pivot I used a .75 shaft and 1" tubing with uhmw for a friction plate. I used new 3x3 angle so I would not have to cut down on seams. Rustileum sail blue paint is the perfect match in color. I'll post how I seammed the grates.
MedfordFFA
Post by MedfordFFA » Tue Oct 09, 2018 9:28 pm
What did you have to change in the program to recognize the new table size?
Return to “PlasmaCam”
