Pcam Ohmic sensor wire
over the weekend .. I had the misfortune of breaking the component in the wire that connects to the Ohmic sensor .. what xactly is it ??? (resistor) im guessin ??? I'm sure it should be available locally and jus soldered back in line .. currently running DHC II with DHC Designedge .. thanx
Re: Pcam Ohmic sensor wire
Best bet is to go to the Plasmacam owners community on their website. I'm sure one of the thousands of owners that share info on that site will help you out in a few minutes. You do have to join to post on that site....you will need your machine serial number to do so. Jim Colt Hypertherm
It is a resistor, but since I have never broken mine....I'm not sure of the resistance. I'm thinking it was 470 ohms...
as always .. Thanx U Jim C .. took old broke down to electronics store and decoded the colored bands and back up and going again .. wish I could get some curly q wire to replace that lil piuece .. lol
Hey Barefoot,
Do you mind sharing which resistor you came up with... Just in case at some point I should have an issue with mine!
Carl
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
- Francisco
47 kOhm
Thank you!
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
- Joe Jones
Yep. Last time I counted, there were THOUSANDS of contributors on the Owners Community.jimcolt wrote:Best bet is to go to the Plasmacam owners community on their website. I'm sure one of the thousands of owners that share info on that site will help you out in a few minutes.
Something like is can be repaired with a few items from the hardware store typically. Its pretty much consists of a wire connected to a diode, protected by some electrical shrink tube and a spade connector on the end. Best bet is to either call plasmacams tech line for any specifics. As mentioned previously, plasmacam's owners community could also be helpful.
