Does anyone have plans cut paths for plasma cams 4x4 table grates.
Thank you
Plasma cam 4x4 table grates
Re: Plasma cam 4x4 table grates
You might take a look within plasmacam online owners community. Lots plasmacam owners on there that could help out. You can also easily order a set at the same place from plasmacam.
Good Luck Brother,
JAG
Good Luck Brother,
JAG
- tnbndr
Did you look at the first thread on the Plasma CAM section??
http://plasmaspider.com/viewtopic.php?f=61&t=2272
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Here are mine. These are for a grate made of 1.5 x 1/8" flat bar and the center slots for the flat bar are offset an inch to give it a curve. This keeps it snug in the slots, and means if you cross a line you won't burn down the whole length. Also ends most tip ups.kenny wrote:Does anyone have plans cut paths for plasma cams 4x4 table grates.
Thank you
Im coming to a mental block looking at your drawing Ironman. What are the 4ft. pieces that are sunk down with only 3 slots for? got a picture of your setup?
