Hypertherm 105A and THC Voltage Divider Ratio Issues
Crich
Post by Crich »
Hi. We're having a problem on connecting the Hypertherm 105A to torch height controller HYD XPTHC-100III.
In Hypertherm 105A we set the ratio to 50:1, while our thc have a fixed voltage divider ratio of 100:1.
What can we do about this?
HypHyDef
Re: Hypertherm 105A and THC Voltage Divider Ratio Issues
Post by HypHyDef »
Hi Crich, Please contact our Technical Support team here at Hypertherm for help getting your Powermax 105 to your THC. you can reach them here:
(800) 643-9878 or https://www.hypertherm.com/en-US/contac ... -questions
Randy,
Hypertherm Inc.
Crich wrote: Sat Jul 09, 2022 3:44 am Hi. We're having a problem on connecting the Hypertherm 105A to torch height controller HYD XPTHC-100III.
Crich - If your 105A does not have the option to set the ratio to 100:1, then you can simply add a 2:1 divider to step down your divided arc voltage to the correct compatible level to match your thc.
