Hypertherm Powermax 65 Fine Cut 45amp consumables
I have a Hypertherm Powermax 65 with the duramax machine torch(non Ohmic retaining cap). When using the fine cut consumables the manual shows two different set ups one with a shield one with a deflector. When I called hypertherm they stated that the 220948 shield can be used on either retaining cap. Does anyone have some in site into this? Thanks.
Re: Hypertherm Powermax 65 Fine Cut 45amp consumables
Sure that shield will fit and work on either cap. I don't use ohmic sensing so I prefer to use the deflector 220955 so I can see the nozzle when I am using finecuts.
