wiring 45xp to table
color of trigger wire ?..where do the other two leads go ?..in powermax 45 , black with red stripe went to workload....red went to J19..what are the 45xp equivalant locations ? Thanks for any help
Re: wiring 45xp to table
You using a hand or machine style torch? I assume your looking to hook up for raw voltage which can be accessed from where the ground clamp is terminated at the PM45 circuit board and where the gang of wires from the torch lead that feed the electrode and terminated at the circuit board. Red typically goes to the ground clamp termination and your blk/red goes to the electrode termination location. I am not familiar with the 45 so these are generic instructions, someone may have an easier place to find your hookups.
