MAX 43 plasma cutter
I have an old Hypertherm MAX 43 plasma cutter with a bad torch. Anyone with information for a replacement torch that will connect directly to the MAX 43 ?
Re: MAX 43 plasma cutter
You may be best to contact Hypertherm and see what they have for you. Good luck.
Maybe you have gotten an answer already, but you can get a new torch for the max43. its a duramax retrofit torch. part# 229816 just got one for mine. consumables are easily obtainable too!
