Hey looking for any input here. Torch has been working great for months. All of a sudden this morning, I come out and turn on the air turn on the torch and turn my table on and the torch immediately fires out of the blue on its own. I hit the switch on the machine torch and turn everything off and now when I turn on my torch I’m getting an 0-51-0 error which the book tells me is a false fire error.
I have no idea how to fix. I’ve unplugged and checked all the wires etc. and closed the software and restarted everything a hundred times in different orders but can’t shake the error. Any ideas....blows my mind that it has worked great for 4 months and then this out of the blue..
0-51-0 error
Re: 0-51-0 error
You should start the controller first and the last thing is the plasma unit. the 65 manual says "power turn on with start signal on"
If you are using a hand torch the trigger may be tripped or with a machine torch it may be a wiring problem. If you are using a machine torch remove the plug (CPC) on the back of the unit that is where it gets the torch fire signal.
Re: 0-51-0 error
I’m using a machine torch. Can’t see where I would have a wiring problem. Been working without issue for months since I first got it. I will try the cycle you suggest and turn the power supply on last in the sequence. I appreciate you taking the time to offer some advice. Thank you
Re: 0-51-0 error
On the wiring problem I'm not saying it was wired wrong but the torch trigger can happen it 2 wires short together at a connection point. If the torch fires when you power up the plasma unit, removing the plug from the plasma and no torch fire happens would show that.
