Trying to help a friend...
Coms between the Host (Windows XP) and the Edge Control died after a series of multiple bad mains glitches. The Host's COM port failed, so I replaced it with a USB-to-Serial convertor - checked, and all ok. However, the Host software still reports a loopback failure with the Edge Control. Edge Control has two COM ports, and using the on-board diags when appropriate pins are linked, both pass ok. Using the Phoenix Link software, I think I have established which COM port and Baud rate is in use at the Control, but not the Parity, Data Bits or Stop Bits.
The problem seems to be how to configure the Edge Control's COM ports. No amount of fiddling with the Host COM Ports parameters will get me communication between the two. The Hyperterm Installation and Setup Guide booklet shows a nice screenshot of a page featuring COM ports, Baud rate, etc., but I cannot find this from the Control's Front panel. Nowhere seems to lead me to this screen which apparently has buttons along the bottom for MACHINE, SPEEDS, LINK, I/O, AND AXES.
Anyone any clues please?
Help with old Edge Hypertherm Control
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- ↳ Introduce Yourself
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
