Hypertherm 380
Hypertherm 380
Can a Hypertherm 380 be used for a plasma table? I purchased a Premier Plasma table recently Im curious if my current machine will work on it. Thanks
Re: Hypertherm 380
I found the search button , with that said does anyone have a Diagram for the splicing needed in order to run the machine?
Re: Hypertherm 380
Don't have a diagram for you but the hook up will be very simple. Does your plasma table have a THC system? If so will it work off RAW arc voltage?
Re: Hypertherm 380
brandon1566 wrote: ↑Wed Oct 23, 2019 10:36 am Can a Hypertherm 380 be used for a plasma table? I purchased a Premier Plasma table recently Im curious if my current machine will work on it. Thanks
yes,
connect the THC to the raw voltage input.... make sure your THC can accept raw voltage though
check your polarity!!!!
service manual here
https://www.hypertherm.com/Download?fil ... &zip=False
