I decided to upgrade to a hypertherm the other day. I bought the setup that came with a hand torch. I bought the CPC cable as well.
I'm having trouble getting it to fire from the computer. I can manually pull the trigger and get it to fire though.
I have the green and black pair from the CPC going to the start stop of the cnc, and the white and black of the CPC going to the + and - on the bottom of a Proma THC.
Any advice would be greatly appreciated.
Hypertherm 45xp CPC cable hand torch help
- CleanCutCreations
Re: Hypertherm 45xp CPC cable help
I'm not 100% certain but I am thinking the CPC cable is only for use when a machine torch is plugged into the machine. Maybe your hand torch trigger not being pulled in is the break in the circuit to fire the torch.
I'm pretty sure weldguy is right. The torch switch connection in the CPC only works with the machine torch. I think there is a workaround posted somewhere that jumps 2 of the torch connector pins with a small wire to make it function with the hand torch. I'll see if I can find it.
This is what I was thinking of. It's for the 45xp, but I would think something similar would work.
http://www.candcnc.net/supportforum/vie ... 567#p10364
- CleanCutCreations
I was not able to open the link because I am not a member of that site, but I did find the work around with jumping to pins.djreiswig wrote: ↑Wed Oct 16, 2019 1:27 pm This is what I was thinking of. It's for the 45xp, but I would think something similar would work.
Thank you very much.
Great. Thanks for letting us know.
CleanCutCreations wrote: ↑Thu Oct 17, 2019 6:31 am I was not able to open the link because I am not a member of that site, but I did find the work around with jumping to pins.
