Hyperthterm HT 2000 LHF trigger
HT 2000 LHF I'm trying to find the trigger wire and the voltage sensor wire, I am trying to connect to a Plasma Cam controller with the Design Edge software. Any help would be appreciated!!
Re: Hyperthterm HT 2000 LHF trigger
That's a complicated unit. I was interested so I found the manual here https://www.hypertherm.com/Download?fil ... &zip=False but way out of my league once I started browsing the connections section.
I have a HT 2000 RHF, but I haven't coupled it up yet. If I get chance I'll have a look for you.
The HT2000 LHF unit is a high frequency start plasma cutter. It is recommended that this unit not be used on any cnc machine that uses a standard office PC or laptop as the control system. The HT2000, as all Hypertherm torches over 125 amps, is a high frequency start plasma cutter. The electrical noise interference from the high frequency circuit will cause interuptions and possible damage to the low voltage control circuitry on the computer and the plasmacam system. PlasmaCam systems work great with the Hypertherm Powermax systems that use a blowback starting systems, I have one in my home shop. Jim Colt
Well thanks for your help Jim, I'm always glad to hear from you and the knowledge that you share with us! Thanks for your reply! Joe C
The manual is vary helpful and interesting! Thanks for your help Weldguy!
