I just set up my new PM 65 on a machine table that has a Blade Runner from CandCNC. The Hypertherm is replacing a Brand X which I had used for several years. I am sure that I will have numerous questions as I get going, but to start with, I noticed what appears to be a loose section in the new machine torch. Is this normal? If not, how do I address it, or do I have the torch mounted incorrectly? Is it okay to send a Dropbox link with a short video? If not, how can I send the vid?
Thank you very much.
New Powermax 65
New Powermax 65
4' x 4' DIY Table
CandCNC Bladerunner
Miller Vintage 250 Mig
Miller Syncro 180 Tig
Bridgeport 2J Mill - Fagor Dro
Southbend 14" x 40" EVS Lathe - Fagor Dro
Brook 18" Metal Shaper
Harig 612 Surface Grinder
CandCNC Bladerunner
Re: New Powermax 65
the torch sections are screwed together like pipes have you tried to tighten it, also there are 3 screws that hold the tip portion on the torch they could be loose.
Re: New Powermax 65
Prior to posting, I did do a search and found this (or similar) posting with photo. I then went after those screws and they seemed tight and I didn't want to over tighten them. I will remove the torch and check again.acourtjester wrote: ↑Sat Dec 29, 2018 2:29 pm the torch sections are screwed together like pipes have you tried to tighten it, also there are 3 screws that hold the tip portion on the torch they could be loose.
Thank you..
4' x 4' DIY Table
CandCNC Bladerunner
CandCNC Bladerunner
Re: New Powermax 65
I just checked again and those screws are tight. Maybe this will help. https://www.dropbox.com/s/xhd9dqexz6775 ... 2.MOV?dl=0Mr. Fixit wrote: ↑Sat Dec 29, 2018 3:13 pmPrior to posting, I did do a search and found this (or similar) posting with photo. I then went after those screws and they seemed tight and I didn't want to over tighten them. I will remove the torch and check again.acourtjester wrote: ↑Sat Dec 29, 2018 2:29 pm the torch sections are screwed together like pipes have you tried to tighten it, also there are 3 screws that hold the tip portion on the torch they could be loose.
Thank you..
Thanks again..
4' x 4' DIY Table
CandCNC Bladerunner
CandCNC Bladerunner
Re: New Powermax 65
Looking at your video I don't think that is right, I would call Hypertherm tech support.
Also Jim Colt replies to post here, I'm sure he will have a comment about that.
Re: New Powermax 65
I appreciate your time and comment.
4' x 4' DIY Table
CandCNC Bladerunner
CandCNC Bladerunner
Re: New Powermax 65
The area that looks loose should have internal threads....it looks like it simply needs to be tightened. It is a large diameter thread machined into both pieces of melamine / fiberglass tube. Jim Colt
Re: New Powermax 65
Jim,
Thank you for your response. I was concerned that I was going to damage something since I feel resistance when trying to turn that part. I checked in with technical support and the gentleman that I spoke with suggested that I loosen the strain relief at the top of the torch And then tighten as you have suggested.
4' x 4' DIY Table
CandCNC Bladerunner
CandCNC Bladerunner
Re: New Powermax 65
This was all that it took. Resolved. Thank you
4' x 4' DIY Table
CandCNC Bladerunner
CandCNC Bladerunner
