help needed hypertherm 1250 wiring
rat119ohio
Post by rat119ohio » Sat Sep 08, 2018 11:40 am
i have a hypertherm 1250 handheld torch wired to my plasmacam i just recently bought a machine torch how do i go about wiring it up.
Ironken
Re: help needed hypertherm 1250 wiring
Post by Ironken » Sat Sep 08, 2018 2:14 pm
There are better versed here on this subject but, here's my .02.......I would think that you would need to order the machine interface cable from Plasmacam that will connect to the cpc port on the back of your 1250 (if equipped). There is also some voltage divider settings in the Hypertherm that needs to match your Plasmacam. I know the newer Hypertherm machines have a field install cpc port kit available for units not equipped from the factory. I don't know if this option is available for your machine.
You may want to repost this in the Hypertherm section as Jim Colt from Hypertherm frequents that section and is a great resource.
rat119ohio
Post by rat119ohio » Sat Sep 08, 2018 10:35 pm
Ok i will look into the info that you have given me thanks it's a good start.
