Modified the item submitted by SSkaggs back in 2021. Have yet to go through and reduce the nodes in the text but Fusion did a good job and the cut points are not excessive. Hope others will convert to DXF for those that prefer that. Fusion has the ability to export as DXF but I've folks tell me that Fusions DXF's have problems.
Modified Father Daughter Fishing
Re: Modified Father Daughter Fishing
This one has about 1/2 the node count of the one I just posted.
Nice work!! Thanks for sharing your effort with us.dbrub2 wrote: ↑Thu Jun 09, 2022 8:31 am Modified the item submitted by SSkaggs back in 2021. Have yet to go through and reduce the nodes in the text but Fusion did a good job and the cut points are not excessive. Hope others will convert to DXF for those that prefer that. Fusion has the ability to export as DXF but I've folks tell me that Fusions DXF's have problems.
Fishing Buddies.svg
Now thats awesome, thank you!
Here is your svg imported to Fusion 360, exported as dxf, and opened with Design Edge. Looks the same as the previous result. Nice work!!
- Larry83301
Very cute file. Thanks to the OP and those that worked on it.
Thanks for the share
