Somewhat Geo Spider Web
Here is a spider web I put together, size 21" x 21" with 1/2' threads. Somewhat more geometric than others I have seen. Hope you can use it.
Re: Somewhat Geo Spider Web
Nice contribution Thanks
Very nicely done! I wasn't sure what you meant by 1/2" threads - I was thinking about threaded bolts or rods. But now I understand.
Thanks for sharing with us.
Makes a neat gusset. Thank you.
- Joe Jones
TXBluegrass ...
I am just curious ...
Is this how you drew it, by trimming out one slice and making a polar array of 32?
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Many ways to do this.
- Joe Jones
True. But when I work in my shop, somewhere in the back of my mind, I hear Frank Sinatra singing, " ... I did it Myyyyyy Waaaaaayyyyy!!!"
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
In any case, I think this is a much easier task for those fortunate enough to be using Design Edge - very powerful editing tool - which last time I checked can be purchased directly from Plasmacam as a stand-alone program for around $3k including advanced design. But still pretty expensive for the average Joe. I remember paying around $1800 for my Aspire license. I used VCarve Pro for several years and then decided to plunk down my hard earned cash for the upgrade to Aspire. I have never looked back.
- Joe Jones
Yep. I have V-Carve PRO, but Aspire is on my Christmas Wish List!adbuch wrote: ↑Sat May 14, 2022 8:23 pm In any case, I think this is a much easier task for those fortunate enough to be using Design Edge - very powerful editing tool - which last time I checked can be purchased directly from Plasmacam as a stand-alone program for around $3k including advanced design. But still pretty expensive for the average Joe. I remember paying around $1800 for my Aspire license. I used VCarve Pro for several years and then decided to plunk down my hard earned cash for the upgrade to Aspire. I have never looked back.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
I tried what Frank S. might try. I rotated a line from the mid grid point 45, 22.5, 11.25 degrees to get the proper spacing then used the bulge feature with equal spacing to do the rest.
- Joe Jones
I'd like to see a video of that! There is an easy way to draw this and keep everything symmetrical. I don't know about other design programs, but DesignEdge could lay this out in a matter of minutes.TXBluegrass wrote: ↑Mon May 16, 2022 9:44 pm I tried what Frank S. might try. I rotated a line from the mid grid point 45, 22.5, 11.25 degrees to get the proper spacing then used the bulge feature with equal spacing to do the rest.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
I would like to see a video of that.Joe Jones wrote: ↑Mon May 16, 2022 10:12 pmI'd like to see a video of that! There is an easy way to draw this and keep everything symmetrical.TXBluegrass wrote: ↑Mon May 16, 2022 9:44 pm I tried what Frank S. might try. I rotated a line from the mid grid point 45, 22.5, 11.25 degrees to get the proper spacing then used the bulge feature with equal spacing to do the rest.I don't know about other design programs, but DesignEdge could lay this out in a matter of minutes.
He is using Design Edge.Joe Jones wrote: ↑Mon May 16, 2022 10:12 pmI'd like to see a video of that! There is an easy way to draw this and keep everything symmetrical. I don't know about other design programs, but DesignEdge could lay this out in a matter of minutes.TXBluegrass wrote: ↑Mon May 16, 2022 9:44 pm I tried what Frank S. might try. I rotated a line from the mid grid point 45, 22.5, 11.25 degrees to get the proper spacing then used the bulge feature with equal spacing to do the rest.
- Joe Jones
Okay. I will find the time to make it for you. The design itself is a polar array of six shapes, centered on a 6" circle. The final design has a 1/4" offset added to the straight sides, to make the two outside webs the same thickness as the others.
Now ... do you want a video of his EXACT design? Because that would take longer, since I would have to measure the exact distances between the quadrants of each arch, etc. in order to duplicate his EXACT design.
But to make a web design LIKE THAT, which would be very similar, it would only take a few minutes.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Lets go with the exact design.
- Joe Jones
Although replication of the EXACT design is entirely possible, I will not waste my time spinning my wheels to entertain YOU by trying to exactly replicate a HAND DRAWN design in which no two measurements are identical. This is not a symmetrical design, David, and YOU KNOW THAT.
So I know you are salivating at the opportunity to drag my DXF file into your computer, and lay it over this design, tripping over yourself in order to point out the 187 places where MY nodes did not line up EXACTLY with his nodes in this design.
I can draw something visually close in a matter of minutes, perhaps close enough as to be difficult to discern the difference with the human eye. It is nothing more than a polar array of six shapes set at 11.25 degrees radial, with an exterior hand drawn border.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- rusty gates
An unusual design and thankyou for sharing.
regards
Rusty...
regards
Rusty...
Rusty's Metal Cut Signs & Designs
Homebuilt 4' x 4' table
MyPlasm CNC Controller & plasma interface unit
Thermacut SD55 Plasma Cutter
https://www.youtube.com/channel/UCKIMjD ... MiyyzSe_Jg
Why so defensive??Joe Jones wrote: ↑Tue May 17, 2022 10:29 pmAlthough replication of the EXACT design is entirely possible, I will not waste my time spinning my wheels to entertain YOU by trying to exactly replicate a HAND DRAWN design in which no two measurements are identical. This is not a symmetrical design, David, and YOU KNOW THAT.
His design looks symmetrical to me, and certainly not "hand drawn". I have no interest in "dragging your dxf" over to compare with the original. So ok then, just draw something visually close. I was just interested to see your video showing you technique, as I expect some others might be as well. It's all about sharing and maybe we could learn a thing or two from your process. You said you could draw it up in a few minutes, and I want to learn from you, so go ahead and make the short video. If you have changed your mind, or are too busy with other things, then I completely understand.
- Joe Jones
Yes, I agree. It LOOKS symmetrical. It isn't.
http://youtu.be/HoyPLTBlSLUI have no interest in "dragging your dxf" over to compare with the original. So ok then, just draw something visually close. I was just interested to see your video showing you technique, as I expect some others might be as well. It's all about sharing and maybe we could learn a thing or two from your process. You said you could draw it up in a few minutes, and I want to learn from you, so go ahead and make the short video. If you have changed your mind, or are too busy with other things, then I completely understand.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Nice use of the array tool! You pattered yours after his using the circles, but now yours is symmetrical. Nice work.
- Joe Jones
There is something to be said for the hand drawn piece. When things are TOO symmetrical, they take on a "MADE IN CHINA" appearance, with no clue that they were created by hand, so in may instances, the hand drawn, hand cut piece is more appealing. I really don't care if things are not perfect. But if they are "off," I want then to be visibly off, and not just subconsciously, irritatingly off. A hand drawn web that is Beetlejuice style is great. But if it looks like the design was supposed to be symmetrical and it isn't, that is just something I pick up on. Maybe it doesn't bother other people. I don't know.
A sign like this would drive me crazy, because I would immediately see the flaw!
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
What flaw Joe? I am trying hard to find one but the only thing I can kinda pick up on is the letters do not appear to be the same height.
- Joe Jones
Exactly. The letter "R" was scaled down just a bit. I have worked in the sign industry for many years, and this is like a poke in the eye to me. Here are some more examples...plasmanewbie wrote: ↑Wed May 18, 2022 12:24 pm What flaw Joe? I am trying hard to find one but the only thing I can kinda pick up on is the letters do not appear to be the same height.
Can you find the errors? They really stand out to me. They are the "Once you see them, you cannot UN-see them" things.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- Joe Jones
Sorry David. I took too many grumpy pills last night. Drama happening outside of this forum that was really grinding on me.
His design is hand drawn in that he probably made the curved web parts as an array and hand rotated them into position by eye, rather than a definite 11.25 degree polar array. The result is curves that start and end at different points around the circle because the center of the curves are not ALL aligned at the 5.625 degree marks. Still, it is a great design for a decorative "gingerbread" dressing on an old home, or to be used as a bookshelf support, etc.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
