Tree of life share
Tree of life share
Here's one that will be your favorite!
Re: Tree of life share
Thanks for the share!
So many versions but this one is nice and clean, thank you for the share.
- hdfaster
It was a favorite when it was shared back in 2010.
THANK YOU!
- jmersereau
PrimeWeld CUT60
Langmuir CrossFire Pro
Thank You!
- kchoghead
thanks
Good evening folks,
I downloaded this file for the 12" tree of life but for some reason when I bring it into myplasm it shows up as 12X17 and has more than one pierce point in some of the cut sections. Is this what folks refer to as clean up of a file?
Try this one. The size is 12 inch diameter. I have joined/linked to all closed paths. It should cut fine.
Thank you so much. I am learning slowly. Your help is greatly appreciated. Mike H.
