kindelng spltter
kindelng spltter
I knew it wouldn't be too hard to draw up but I figured id ask to see if any one has made something like this first
- Scratch
Re: kindelng spltter
Got a video on this? I'm interested in seeing how good it works.
This is just a picture i pulled of the internet I'll search YouTube to see I'm sure there is
- SeanP
Just so happens I have just the ticket for you!
All parts cut from 6mm
I heated up some plastic water pipe to go on the handle.
Ideal for kindling as long as it's not to knotty.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
Dude you are awesome!!! Thank You
Thanks i will cut one today for the wife
Hypertherm 65
Hypertherm 65
Sean to go along with this you should post your chain saw log cutter
- SeanP
All the dxf files should be there now
Powermax XP45
Table build gallery
Table build gallery
- SeanP
Ahh go on thenacourtjester wrote: ↑Fri May 08, 2020 2:27 pm Sean to go along with this you should post your chain saw log cutter
Old bandsaw blade for the springy bar.
https://youtu.be/zLMSbXQjvQ4
Powermax XP45
Table build gallery
Table build gallery
Seanp do you have some measurement on that
It sure wounld help
REX
It sure wounld help
REX
Hypertherm 65
Hypertherm 65
- SeanP
Is that the chainsaw holder?
Trouble is all saws are different, you will need to make to suit your own saw.
Powermax XP45
Table build gallery
Table build gallery
Sorry I did say it was the kindling splitter I need to know what measurements
REX
REX
Hypertherm 65
Hypertherm 65
Thanks, good project for a Saturday
- SeanP
The dxf files are metric, just cut and weld to picture.
Powermax XP45
Table build gallery
Table build gallery
Great share Thankyou
For some reason when I open them up all of the parts show up like 400" long. do you have measurements so I ca convert them from metric
I just changed scale when I imported dxf to 3.94% and now its in inches
cool Ill give that a try thanks
- ETCWeld
Neat and extremely different approach!
Joe Peterson
4'x8' TM 2 Water Table
TD A80
Flashcut CAD/CAM/CNC
Eastwood QST 30/60 Scroll Comp
ESAB Rebel 215ic
TD A80
ESAB Rebel 215ic
since I'm pretty new on plasma cutting, I got some troubles to nest it wihout losing all the right measurements
do somebody has the file nested or can help me out nesting it would be much appreciated
I opened these in Corel and using the Automatic scale selection and they measurements were all wrong also. Ended up opening them using the metric mm scale selection and everything looks good. Attached is a nested file, hope it helps.3axesdesign wrote: ↑Tue Sep 21, 2021 9:16 am since I'm pretty new on plasma cutting, I got some troubles to nest it wihout losing all the right measurements
- tinspark
I added about 10" to the handle on the one that I burned a while back. Used 1/4" plate and doubled up the 1,4" at the handle. I am glad I didn't purchase one of these things. It is ok on dry 2x4's and softer wood, but I don't use that stuff too often. Though it does work, for me it is much faster and less frustrating to use a small hatchet for my kindling . That's probably what I am used to using I guess..
I have mine mounted out back near my wood pile and it is basically a conversation piece..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
thanks so much pal !! I produced one out of 1/8 plate left over and its going trough wood pallet wood. i gonna get some 1/4 to see if it can break appart some of soft wood logplasmanewbie wrote: ↑Tue Sep 21, 2021 9:58 amI opened these in Corel and using the Automatic scale selection and they measurements were all wrong also. Ended up opening them using the metric mm scale selection and everything looks good. Attached is a nested file, hope it helps.3axesdesign wrote: ↑Tue Sep 21, 2021 9:16 am since I'm pretty new on plasma cutting, I got some troubles to nest it wihout losing all the right measurements
KindlingSplitter.dxf
