Need .PCM converted to DXF!
I have 2 .PCM files that I need converted to a DXF so I can export. I have old Plasmacam software so I cant do it myself. I need to get it exported as soon as possible. Thank you!
Re: Need .PCM converted to DXF!
Try this. RK
Thank you very much Russ! I really appreciate it.
Just so you know, you can convert these from .pcm to .dxf in Plasmacam. When you export the file it automatically exports to .dxf.
Greg
Greg
- ben de lappe
Disclaimer: No P-Cam exp.,
But you are correct. 3.1 will not export as .dxf. One needs the upgraded version of the software.
