DXF Guy Freebie - Country Themed Sawblade Welcome
DXF Guy
Post by DXF Guy » Tue May 14, 2019 10:47 am
Here is a country themed saw blade welcome sign that I hope some of you can use.
Designed to be 24" in diameter, some mods may need to be made to cut smaller.
Have a great week everyone :Yay
sawblade_deer.dxf
sbest1
Re: DXF Guy Freebie - Country Themed Sawblade Welcome
Post by sbest1 » Tue May 14, 2019 10:56 am
Love it. Thanks for sharing
otisa2007
Post by otisa2007 » Tue May 14, 2019 6:02 pm
looks great thanks for the share
Jeepn2
Post by Jeepn2 » Tue May 14, 2019 8:52 pm
Thanks for sharing
Precision Plasma Patriot 4X8, Proma THC (if I can get it working), Floating head
Hypertherm 45 - hand torch
Mach3, Sheetcam, Inkscape/Corel X5
Lincoln Squarewave 175 tig, Miller 185 Autoset
Southbend Heavy 10X48 lathe
Bridgeport 9X42
Grizzly Mill/Drill
hdfaster
Post by hdfaster » Wed May 15, 2019 8:37 am
Thank you!
ian.
Post by ian. » Wed May 15, 2019 9:01 am
Thank you very much!
Lanemfg
Post by Lanemfg » Wed May 15, 2019 10:17 am
beautiful, thank you!
K D Metalwerks
Post by K D Metalwerks » Wed May 15, 2019 4:45 pm
Great share as usual. Many thanks!!
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
david jordan
Post by david jordan » Thu May 16, 2019 7:24 am
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
JohnnyC
Post by JohnnyC » Thu May 16, 2019 10:21 pm
Thank You!
firewood57
Post by firewood57 » Fri May 17, 2019 6:24 pm
very nice thanks!
Welder Kenny
Post by Welder Kenny » Fri May 17, 2019 10:52 pm
thanks It's a great design, any help on cutting the fine detail I used fine cut tip and lowered amps but lost some of the detail around deer nose and ear.
leslie_hughes
Post by leslie_hughes » Sat May 18, 2019 9:53 pm
Thank you so much for sharing, I'm still a newbie, learning every day and I have most definitely come to appreciate the amount of work it takes to do these designs. Once again THANK YOU THANK YOU for sharing
Searchman
Post by Searchman » Sun May 19, 2019 6:17 pm
Thanks for the great share
Metaspec
Post by Metaspec » Mon May 20, 2019 10:32 pm
Thank you for the share that's great looking
Lanemfg
Post by Lanemfg » Fri May 24, 2019 11:42 am
Rudy198
Post by Rudy198 » Sat May 25, 2019 7:58 pm
Thank you.
Bor21
Post by Bor21 » Mon Jun 17, 2019 2:51 pm
good one! thanks for sharing.
Powermax 85
Bladerunner CandCnC
SheetCam, Mach3,
Inkscape, Gimp
Lots of home BREW
