Navy Seal Boat Team 12
Kind of proud of this one. 36" diameter multi piece multi layer candy finish (25+ pieces). Presented at Coronado Island Navy Training Facility. A scheduled 15 minute photo op session turned into over an hour as other Seal Teams posed with the piece. It was then put on high speed boat and taken to Virginia Beach to show to another Seal Team, then to Mississippi to show to another. Finally returned back and displayed permanently on Coronado Island. Took me quit a while to complete and several design challenges but it was a success.
- Scratch
Re: Navy Seal Boat Team 12
Awesome work! How did you do the lines in the rope around the edge?
Thanks. Its the marking feature on the Hypertherm 45 XP. Its a long process with the PlasmaCam due to their software lock downs. Have to wait till the torch stops blowing after each mark before you can start the next, otherwise the torch moves before it fires. Its like $1000 to upgrade so it does not do that. I actually upgraded to the XP just for that feature to do the rope on this piece.Scratch wrote:Awesome work! How did you do the lines in the rope around the edge?
Big Bravo Zulu to you looks fantastic
- ben de lappe
Very nice work!! Be proud of that one.
- rdj357
Do you not have any height control at all? The wait for cutting signal before moving should take care of that?rickjamesbish wrote:Thanks. Its the marking feature on the Hypertherm 45 XP. Its a long process with the PlasmaCam due to their software lock downs. Have to wait till the torch stops blowing after each mark before you can start the next, otherwise the torch moves before it fires. Its like $1000 to upgrade so it does not do that. I actually upgraded to the XP just for that feature to do the rope on this piece.Scratch wrote:Awesome work! How did you do the lines in the rope around the edge?
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Nope. Just stock machine.rdj357 wrote:Do you not have any height control at all? The wait for cutting signal before moving should take care of that?rickjamesbish wrote:Thanks. Its the marking feature on the Hypertherm 45 XP. Its a long process with the PlasmaCam due to their software lock downs. Have to wait till the torch stops blowing after each mark before you can start the next, otherwise the torch moves before it fires. Its like $1000 to upgrade so it does not do that. I actually upgraded to the XP just for that feature to do the rope on this piece.Scratch wrote:Awesome work! How did you do the lines in the rope around the edge?
did you use argon for the marking? seriously thinking about using marking so just curious if argon or air is the way to go . thanx and nice piece
Great Job
Looks great !!!!
Cornelio
Cornelio
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
Thanks.. Just AirBillythegoat wrote:did you use argon for the marking? seriously thinking about using marking so just curious if argon or air is the way to go . thanx and nice piece
That is very nice. How did you attach the layers.
- dgeorgester
the patinas are just awesome.
On a sign this size I weld a threaded collar or nut to the backside of the piece and bolt on from the back. On smaller pieces I use super magnets. All pieces are removable so they can be replaced if accidentally damaged.blackandtan wrote:That is very nice. How did you attach the layers.
I have read about other people using magnets, I guess I need to try it.
