F Bomb Bottle Opener
After cutting out, grind the round part on a angle.
- otisa2007
Re: F Bomb Bottle Opener
nice thanks
pretty cool
Very cool, thanks for uploading
What thickness would you suggest?
Samson 510
Hypertherm powermax 1250
campbell hausfeld 60 gal
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Miller diversion 180
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Are you guys cutting bottle openers on stainless ? I'm just curious …………………………………… thanks
Bump
Samson 510
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
This is awesome!
Slight re-hash of the file
Thanks for sharing.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
How did you get that finish?
Samson 510
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
I'm new to CNC Plasma cutting, I tried cutting this but couldn't get the F to cut out, could you share gauge of metal used and cut speed.
Ron
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Its just cold rolled 14ga with a quick wet/dry sand with 320 in one direction, not really "finished" so much...
