Another weld jig
Scratch
Another weld jig
Post by Scratch »
Finally got some time to weld one of these suckers up. I know there are a few different designs of these on here, so I thought I'd throw in the design I like best, maybe someone else will like it. It's super simple and you all can probably draw it up yourself, but I thought I'd share it anyways because sharing is caring right?
I didn't want the holes in it since I figure I'd be clamping it to the table anyways. I did want to be able to fit a vice grip in there... hence the slots. It's 1/4"x4"x12"x12", and the center "web" is in the center of the jig, not flush on the flat edge like some.
Enjoy!
(There are two of the center pieces in the drawing because waste is bad)
12x12x4square.CDR
12x12x4square.DXF
Re: Another weld jig
Pretty sweet Scratch. Sharing is caring :D Thank you!
otisa2007
Post by otisa2007 »
nice thankyou
whiskeymike
Post by whiskeymike »
Nice, thanks for sharing. Have you considered using notches or cutting the corner off so you access inside corner for welding?
Old Iron
Post by Old Iron »
Thanks for sharing.
Unfortunately my Qcad won't let me work with it.
Rex
Post by Rex »
Thanks I can use that
Hypertherm 65
Jason@bc
Post by Jason@bc »
thanks a lot, looks like another useful tool.
Searchman
Post by Searchman »
A very useful share. Thanks
sunnybunny
Post by sunnybunny »
shalfpap
Post by shalfpap »
:mrgreen: Thanks for sharing!!
mayper
Post by mayper »
Thanks for sharing
SlagBandit
Post by SlagBandit »
Good idea! Thank you !
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
mardybum
Post by mardybum »
Another to drag up from the depths.
Thank you for the share
RONWB
Post by RONWB »
thanks
Thesteelcave
Post by Thesteelcave »
Thanks looks great!
jmersereau
Post by jmersereau »
This will come in handy and save me some $$$'s, thanks.
PrimeWeld CUT60
Langmuir CrossFire Pro
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Rockdog
Post by Rockdog »
Can not have enough weld jigs. Great idea, Thank you.
mywifestruck
Post by mywifestruck »
Thanks for sharing
reklez2010
Post by reklez2010 »
Great Share. Thank you!
That's a great design! And a very handy tool to have for quick setups.
oneoffgarage@gmail.com
Post by oneoffgarage@gmail.com »
Thank you
