I am working on this for our high school baseball team and I was wondering if someone could help me convert picture to DFX file so all I would have to do is put to cut path and cut it out.
Choctaw Baseball Logo
Re: Need help converting to cut DFX file
Thank you looks great
Re: Need help converting to cut DFX file-Baseball Sign
Can someone help me by putting BRONC in place or CHOCTAW and then make another one that has BRONC on top and SOFTBALL on the bottom. Thanks in advance.
thank you for sharing
Re: Choctaw Baseball Logo
James.Davis.
How did you get the Choctaw letters to curve around the baseball? What program did you use to do it in?
Ernie Dunn
Ernie Dunn
- jmersereau
Ernie,
I am not James but I use LightBurn to curve text around a circle or follow multiple curves. LightBurn is designed to output for laser engravers but it also exports SVG's and DXF's and I learned it when I got my laser, then kept using it for my plasma. It can use all your installed system fonts.
There are lots of great YouTube tutorials on how to do this, here is one... https://www.youtube.com/watch?v=s9f8m-DzndI
Jim
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Thanks Jim, I will check it out!
