Any luck? I have a 21 turbo in the shop.Hooligan26 wrote: ↑Thu Feb 10, 2022 9:47 pm Yes unfortunately most of them are for wrong year and wrong models. Was hoping someone had the correct year pattern so I could customize for my machine.
RZR grill DXF for plasma cutting
Re: RZR grill
Re: RZR grill
If you've got one there you can measure, then draw up a sketch showing the mounting holes layout and locations (with dimensions) and I'm sure someone can draw this up for you. In addition to the dimensions, you should provide some idea of what sort of artwork, lettering, etc. you want.Biltstrong wrote: ↑Mon May 23, 2022 4:51 amAny luck? I have a 21 turbo in the shop.Hooligan26 wrote: ↑Thu Feb 10, 2022 9:47 pm Yes unfortunately most of them are for wrong year and wrong models. Was hoping someone had the correct year pattern so I could customize for my machine.
Re: RZR grill
I’m looking to get an American flag grill for a 2018 polaris non turbo and a 2020 polaris turbo both 4 seaters does anyone have the files for the svg or dxf files? Thanks
Re: RZR grill
Welcome to the forum Mike! Since this is your first post, perhaps tell us a little bit about yourself, your table/cutter, what design software you are using, and maybe post some photos of some of your recent projects. If you happen to own the two vehicles you are asking about, then my suggestion would be to measure and draw up the basic outlines with mounting bolt patterns for these grilles, and then someone here can help you to edit to include the American flag into your design.
Re: RZR grill
Mike - here are a few images of similar grilles for the polaris. If you can supply something like these drawn up with some dimensions, then it will be much easier to help you with your project.
Re: RZR grill
Also you could get some ideas here.
https://www.google.com/search?q=2018+po ... efox-b-1-d David
Re: RZR grill DXF for plasma cutting
Hey guys does anyone know if any of these grilles that are on this post will fit a newer 2022 RZR Xp1000 Turbo? It’s my buddy’s birthday and I’m trying to surprise him with it otherwise I would just check and measure his factory one
Pretty confident that the 2022+ grill is different than previous models.
