It is currently Thu Oct 18, 2018 10:58 pm
Tracked Excavator
SeanP
Tracked Excavator
Postby SeanP » Sun Dec 21, 2014 3:02 pm
I traced this recently, might come in for someone.
Tracked Excavator.zip
Powermax 45 with Duramax torch.
R-Tech 210 Tig, Jasic 250 mig
Sheetcam, Scanything, Coreldraw X8, Solidworks
Table build gallery
beefy
Re: Tracked Excavator
Postby beefy » Sun Dec 21, 2014 3:07 pm
Cheers Sean.
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
plain ol Bill
Postby plain ol Bill » Sun Dec 21, 2014 4:46 pm
Good one - thanks Sean/
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Zippo
Postby Zippo » Sun Dec 21, 2014 7:12 pm
Thanks for posting.
Jeff M
Postby Jeff M » Sun Dec 21, 2014 11:35 pm
Nice file. THANKS !!!
sbest1
Postby sbest1 » Wed Dec 24, 2014 10:45 am
Thanks for the file
CNCCAJUN
Postby CNCCAJUN » Wed Dec 24, 2014 10:49 am
Thank you . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Armotorsport
Postby Armotorsport » Wed Dec 24, 2014 12:34 pm
Cheers that is a good one, what model is it??
SeanP
Postby SeanP » Wed Dec 24, 2014 5:58 pm
Armotorsport wrote:Cheers that is a good one, what model is it??
Thanks, sorry I'm not sure of the model.
It looked well on a weathervane.
All the best.
Table build gallery
MetalTorcher
Postby MetalTorcher » Wed Dec 24, 2014 9:35 pm
That looks awesome Sean! Would you happen to have the dxf of the weathervane as well or did you use one of the files from here?
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
SeanP
Postby SeanP » Thu Dec 25, 2014 10:10 am
MetalTorcher wrote:That looks awesome Sean! Would you happen to have the dxf of the weathervane as well or did you use one of the files from here?
Thanks, keep an eye out, I have two versions of weathervane, I'll do a separate post for those soon,
All the best folks.
Table build gallery
grindergary
Postby grindergary » Fri Dec 26, 2014 9:07 am
Wow, that weather vane is awesome Sean.
Thanks for the share.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel DrawX6, V Carve Pro
Miller CTS 280 Miller Mig
Diesel
Postby Diesel » Tue Oct 13, 2015 12:45 am
Excellent file - thank you!
Customer requested a name be added - so I used the scribe and am pleased with the outcome.
(Note: I cut this from a small piece of 16GA...I thought I had enough room, but I didn't. The far right side overlapped slightly with a previous cut...so I had to modify it a bit with an angle grinder. Not ideal...and I learned my lesson...but it will still look pretty cool on the wall once painted.)
Cheers,
Matt
Custom LDR Motion Systems 5x10 table w/ rotary axis and scribe
Hypertherm Powermax85
Quincy 325 compressor
Ingersoll Rand D18IN refrigerated air dryer
Millermatic 251 MIG
Everlast PowerPro 256 TIG/stick/plasma w/ water cooler
LakeCruiser
Postby LakeCruiser » Tue Oct 13, 2015 3:58 pm
Thanks Sean.
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Craig
Postby Craig » Tue Oct 13, 2015 4:36 pm
Nice weathervane Sean I might have to make one. Craig Johnson
Craig Johnson
mcagauto
Postby mcagauto » Wed Oct 14, 2015 10:20 pm
Home Built 5*5 table pm45
Bobcat320
Postby Bobcat320 » Thu Oct 15, 2015 3:55 pm
Nice work!
I have a friend who would really like this, along with his company logo on it like Diesel did!
Thanks for the share!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
[email protected]
Postby [email protected] » Sat Sep 22, 2018 6:52 pm
Nice!! Thank You.
david jordan
Postby david jordan » Mon Sep 24, 2018 7:48 am
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
Illustrator CS6
400amp mig welder with dc tig
CRP Bench Top Pro
Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
ggeh
Postby ggeh » Wed Sep 26, 2018 10:02 am
That is the coolest construction weathervane I have ever seen thanks for sharing
swcfab
Postby swcfab » Tue Oct 02, 2018 6:41 pm
Great looking piece!
Users browsing this forum: bdeihl570, Fastyankee, Mesquite, SpaceMonkey, tinspark, towman1002 and 18 guests
