T-Rex Dinosaur
- tomloewen
T-Rex Dinosaur
T-Rex Dinosaur
- CNCCAJUN
Re: T-Rex Dinosaur
Thank you for sharing . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: T-Rex Dinosaur
When I opened up your file...the lines were JOINED!! Did you do some playing around and get that part of it figured out? Looks good, just found 2 intersections. Pretty soon you won't need me messing with your files.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
- tomloewen
Re: T-Rex Dinosaur
Oh crap! I just deleted the file to remove a few more nodes, then posted it again. Hopfully for the better . . .MetalTorcher wrote:When I opened up your file...the lines were JOINED!! Did you do some playing around and get that part of it figured out? Looks good, just found 2 intersections. Pretty soon you won't need me messing with your files.
Re: T-Rex Dinosaur
Looking great Tom, your on fire. Nice flowing lines, no breaks and good node count.
Did you do that one in Corel?
Murray
Murray
- tomloewen
Re: T-Rex Dinosaur
muzza wrote:Looking great Tom, your on fire. Nice flowing lines, no breaks and good node count.
Murray
I want to lie and say, I sure did but no . . . ole dog thing. I am getting better with Corel though and I can now see it's far superior to Draftsight for this type of work.
Tom
Opps, I just noticed a few more things. I should have broke up some of the longer lines by the head/neck and gut. That would give the piece more strength after cutting.
Re: T-Rex Dinosaur
this is really cool thanks for the share
- 4.5 Star Member
Re: T-Rex Dinosaur
Thanks very much Tom.
That's a cute little lad in the photo by the way.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
- tomloewen
Re: T-Rex Dinosaur
beefy wrote:Thanks very much Tom.
Keith.
Yep, that's my grandson We've had two more since
Tom
Re: T-Rex Dinosaur
Very nice file for sure!!!!! Bet your proud of them grand kids as well!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- tomloewen
Re: T-Rex Dinosaur
Largemouthlou wrote:Very nice file for sure!!!!! Bet your proud of them grand kids as well!!
Yep
Re: T-Rex Dinosaur
Thanks for the TRex file. I cut it out using 1/2" Baltic Birch Plywood. Used a 60 degree V-Bit at .050 depth for the engraved lines and then a 1/8" 3 flute end mill for the cut out. Need to work on painting skills but 5 year old grandson was happy with it!
Probotix Meteor CNC Router
Vectric VCarve Pro Software
- Larry83301
Re: T-Rex Dinosaur
Looks great! Glad to see someone else does some of their work in wood.
Re: T-Rex Dinosaur
I cut this one for my grandsons for Christmas, I'ts going 9' in the air on top of their swingset, I welded the long line on the neck for added strength, I need to cut the base back off to get the right angle of stance. Thanks for this great file
Re: T-Rex Dinosaur
Thank you for the share
Re: T-Rex Dinosaur
Cool! Had not seen this one before. Thanks for the share Tom!
- tomloewen
Re: T-Rex Dinosaur
Yep, but there was a little problem with this file . . . I did this one in my earlier stages of dxf art. The cut line between the head and body should have been broke in the middle, or at some point. Otherwise there's very little holding the head to the body.plasmanewbie wrote: ↑Wed Feb 13, 2019 10:07 am Cool! Had not seen this one before. Thanks for the share Tom!
Re: T-Rex Dinosaur
cool!! thank you
